Okeke
Hi everyone,
I’m an independent audio plugin developer, and I recently released MixBrain v2 for Mac.
MixBrain is a VST3/AU mix preparation assistant designed for a common home recording problem:
Individual tracks may sound fine on their own, but the full mix becomes crowded, muddy, harsh, or difficult to balance.
The plugin uses a Master + Node workflow.
- MixBrain Master goes on the mix bus
- MixBrain Node goes on individual tracks
- The system compares the full mix with track-level information
- It then suggests coordinated starting points for EQ, compression, saturation, transient shaping, and space-related adjustments
It is more like a second set of ears that helps point out where the mix may need cleanup, especially masking, low-end buildup, dense midrange, harshness, or staging problems.
There is a Free edition available, so I’m mainly looking for real-session feedback at this stage.
Current status:
- Mac only for now
- VST3 / AU
- Free edition available
- English mode is included
- I’m still refining the UI, wording, and suggestion behavior based on user feedback
Especially:
- DAW name
- macOS version
- Apple Silicon or Intel
- VST3 or AU
- What kind of session you tested it on
- Anything confusing, broken, or not useful
https://kiyohbimbo.gumroad.com/l/rgjgus
Thanks,
Kensuke / AudioBrain
