T
Theheat
I am Purchasing the HD24 and an Imac G5 do i need dual processors or not to mix and master with protools???
Theheat said:I am Purchasing the HD24 and an Imac G5 do i need dual processors or not to mix and master with protools???
Fishmed_Returns said:If you are getting an HD24, then you should get a device so that you have the ability to mix all of the tracks, like a 24 Ch mixer. If you want to record with a computer base system like the Digi002, then you really don't need the HD24.
What are your recording goals?
DAWG, what's been up!!??
Track Rat said:Outstanding sir!
Trackrat is very right. Console good.Track Rat said:Yeah, a console is just about a must have to go with the HD24 if for no other reason than to set up monitor mixes while tracking. I use a MOTU 2408 to do real time transfers in and out of a computer via Lightpipe.
You could use the "cuemix" if you ended up getting a motu 2408. That is the Motu's monitoring software program. It is kind of nice to use as a monitor,but console is MUCH nicer
