K
keithpurtell
Most is good with the upgrade to an M-Audio Delta 1010LT (on Win XP SP3). But here's where some weirdness with Audacity starts: When I brought Audacity files (and folders) home from a recording I made at work (Win 7 64-bit). I had also used Audacity (2.0.1 on both PCs) to output a WAV and an MP3 of that first version while at work.
With the new audio card at home, the WAV plays fine in Windows Media Player, the MP3 plays fine in WinAmp, but If I launch playback of the source in Audacity, distortion is horrendous. There's no clipping; amplitude is well within reason. Output volume from Audacity is set at about 60% -- changing it has no effect. Also tinkered with the Default Sample Format in Audacity but no luck. Tried changing the DMA Buffer Size in the Delta; no luck.
The card doesn't demand ASIO, so that's not it. In Audacity, any/all tests using any permutation of Windows DirectSound as Audio Host is horrendous regardless, for whatever reason. MME and a few of the following combinations are reducing the distortion from horrendous to merely awful, but that's progress. The drop-down next to the speaker icon (Output Device) is set to channels 1/2, which I've confirmed are routed to my powered speakers. That leaves the mystery of where to set the drop-down next to the mic icon (Input Device)? Both Microsoft SoundMapper and the card's "Multi" option are more awful. All the other options -- like 3/4, 5/6, etc. -- are somewhat less awful. No luck messing about with preferences/devices. I'm running out of knobs to twiddle. What next?
