M
Masterofnone
I've got an oppertunity to become the sound guy for a friend's band that plays at venues state-wide, but honestly, I don't know how it's "really" done!
When I've done it before for some others, we've had to jury-rig the equiptment to get it do do what we needed (using the wrong stuff for the job
), and I just messed around until it sounded right. We were using a really big Mackie, a pair of Crown? 800w power amps, and some verry nice JBL PA/monitor speakers as that is what we had access to and all we were allowed to use.
So, I'm guessing the common practise is to mic the drums, DI the bass and mic the guitar amps? We've have never used seperate preamps, just what came with the equipment we were using. Is the use of seperate preamps a standard/often done thing? From what I've seen, just use an analog mixer?
This seems to be a better/more productive/cheaper route than starting off learning home recording as I had originally planned.
I'm sure I'll have more questions as I think of them, but this should get me started...thanks in advance.
--Kyle
), and I just messed around until it sounded right. We were using a really big Mackie, a pair of Crown? 800w power amps, and some verry nice JBL PA/monitor speakers as that is what we had access to and all we were allowed to use. So, I'm guessing the common practise is to mic the drums, DI the bass and mic the guitar amps? We've have never used seperate preamps, just what came with the equipment we were using. Is the use of seperate preamps a standard/often done thing? From what I've seen, just use an analog mixer?
--Kyle
, his own amplification usually has enough juice to fill the room without requiring reenforcement through the PA. There is a caveat either way you go with this one; if you go un-reenforced on the bass (which is how I work with virtually all the club-circuit bands I work with), then it takes proper manual communication with the bassist during the sound check to have him adjust his cab properly. OTOH, if you're just sitting back behind a console and controlliing a DI feed of the bass to the PA, you're still going to have to communicate with him if his cab is too loud; you can turn him down to zero on the PA, but if his on-stage cab is booming too much, there's nothing you can do about that from the PA/FOH console...you'll still have to tell him to turn it down on his end.
and the git needs help getting above it, and 3) their PA system is bass-heavy on the amplification due to a pair of Eliminator subs sitting under their EV mains, and the git needs some reenforcement there too. So in these situations that can go either way; it's your call.
Vocals..duh! Makes sense...thanks a bunch
