A
AndrewClaycomb
I'm setting up my control room, but I need to be able to run my snake through the wall along with some other cable for my headphone amp. There is only a single wall (2 layers of drywall) between my tracking room and the control room so this shouldn't be too complicated.
What do I need to get to make this look as clean and inconspicuous as possible? I don't want an open hole in the wall without some sort of fixture over it. Also what the best method of keeping sound from coming through the hole in the wall and bleeding into the control room and vice versa?
My Snake is only 8 channels without a return, so this doesn't need to be a huge hole. From what I understand, I don't want it near any other wire already running through the wall (otherwise I might run it through an existing cutout, such as coax jack or phone jack). Do they make some sort of pvc tube that just inserts directly through the wall with hoods on both sides preventing you from looking into one room from the other?
