C
cdawson
Hello;
I have been recording for years. My first discussion is going to be on input levels. In the digital world zero is the max you want your analog level to read on your meter. ANYTHING ABOVE WILL BE DISTORTED. I like to keep my input level at around minus 5 with peaks just barely touching zero. This gives me the clearest signal to my machine. If the instrument you are recording has more of jump than this there are ways to control the level. The most used is compression. You can also live with bringing down your input and allowing for higher peaks in your recording. say jumps of minus 15 db to zero. The most important thing to remember is your ear is always true. make different settings and listen to your recording. Keeping your levels near zero will insure that you are getting the best recording that is possible from the equiptment you are running.
Have a great day
illumination.name
Have a great day
illumination.name
