R
ritb
How to reduce Noise level of my Mackie 402 VLZ3?
I have noticed that when I turn my fast track pro and mixer levels at full there is a thick noise introduced and thats without turning phantom power on. I have connected mixer with FTP with the help of balanced TRS cable. Still, mixer increases the noise levels by 30dB. Mixer gain is at '0' at this point. I can't turn up the gain at any level because it increases the noise/hiss exponentially. I feel helpless at the inputs which are very low. Any way to eliminate the noise/hiss completely (during recording)?
I have also noticed that when I tried to record only FTP(Mixer turned off) the noise level is -57dB. When I turn mixer on(Gain=0, level full +12dB, Phantom power off) the noise level goes to -27dB. So it is clear that the noise/hiss is introduced by mackie only. Any solution for this?
Mackie 402 Vlz3>TRS-TRS>M-Audio Fast Track Pro>USB>PC
-To avoid Much noise I keep the FTP level at 2 o' clock I use TRS so keep the setting at line.
-I have only plugged in AKG P 120. So when phantom power is off and keeping the levels at Mackie and FTP at full the noise level is -27dB. When I turn off mackie and keep the FTP level at full the noise level is -57dB. Therefore clearly mackie adds 30 dBs of noise. If I turn on the phantom power at this point the noise level shoots up to -6dB(Levels at full)
-Mackie & PC are connected to same APC UPS. FTP is powered with USB. I have connected mackie to UPS with a 240V to 120V converter.
-No PC and Mackie both connected to same UPS and UPS to 1 power outlet
-I tried to use RCA-TS cable from Tape out and it gives same level of noise, using TRS-TRS from balanced main out doesn't reduce the noise.
I hope it clears up the situation for possible advice. TIA
