B
Beck
Guest
Tim,
What do you make of what appears to be an "oxide line" at the top of the tape path, especially on the two rollers at either side of the pic and the capstan? Is it possible that there's either something abrading the top edge of the tape or an alignment issue affecting it in that area.
ChrisO![]()
Not sure, but yeah if the reel tables are too high or the guides too low, or both there could be some excessive rubbing at those points. Also the upper part on the rollers could be easier to miss while cleaning so might have some buildup. The oxide on the capstan is pretty even, which is typical of shedding tape. IMO, this is way to much oxide comming off regardless.
just a comment from my experience with the RMGI tape...I know a lot of 1/2" decks were setup for the 12.5mm tape popularized by, um, Ampex/Quantegy right? Whereas the RMGI tape is slit at the more true 12.7mm standard. Is there any potential issue like this for the 1/4" tape?
This shouldn't be an issue with 1/4". Here are the widths for some common 1/4" tapes:
3M/Scotch 207 -- 6.35mm
RMGI LPR35 -- 6.3mm
Ampex/Quantegy 407/457 -- 6.3mm
Maxell UD 35-90 -- 6.25mm
Not a huge difference. I suppose it's possible if the lifters are worn flat with narrower tape, but I remain sceptical about the width explanation from RMGI. Besides, worn lifters will cut into tape no matter what kind of tape wore them down. One thing nddhc could try is to clean the tape path really well and then play the tape from beginning to end... no rewinding or fast forward so the lifters won't touch the tape. The lifters don’t look worn to me from the pics, but it’s something to try.
The guy left me with a few boxes of open, used Ampex 457 and suffered badly from Sticky Shed. From the box design it looks like it is from the late 80s. Im not sure what other tape to try besides RMGI that I can still purchase new?
You can get the tapes that I listed in my previous post from eBay. You might even be able to find a reel at a local Radio Shack, but they’ve stopped making them. They had them at my local RS as recently as a year ago. The best bet is to look for a Radio Shack dealer in the phonebook. They are a bit different than the regular RS stores because they keep a lot of old stuff on the shelves. RS dealers are usually part of another store like ACE or True Value Hardware.
By the way, I’ve always used denatured alcohol for cleaning tape paths since my A/V days (1978), but don’t use it on rubber. It’s actually the purest alcohol, evaporates quickly and leaves no moisture or residue behind. But a lot of folks use 91% Isopropyl or greater with good results. You will have to get 99% to equal the properties of denatured.
