Slackmaster2K said:
I've often done 24 track 24bit/48khz recordings with multiple high quality effects. No problems. Not a souped up machine either, just a Celeron 850Mhz, 256MB, 7200RPM HD's, Delta1010, etc.
Thanks - that is exactly the type of real-world experience I was looking for.
If you're not looking to do more than 32 tracks of 24bit/96khz, I would avoid RAID 0 because a) it can make the machine harder to setup and maintain b) you won't need the extra power c) you double your chances of data loss d) it costs more. Not to say that it can't perform pretty damn nicely, but it is never recommended to buy power that isn't required.
I really wish it was as easy as CPU and Hard Disk speeds...but there are so many variables that can dictate whether you're going to have a good time recording, or be pulling your hair out. You're more likely to run into "weird" performance issues (bus congestion, bad drivers, etc) long before you hit the theoretical limits of your CPU and hard drive in terms of *track count*.
I typically think of 32 tracks as being the best that should be expected out of a decent DAW. Maybe somebody'll be doing a lot more than that, and maybe somebody can't even come close, but 32 is the magic limit as far as I'm concerned at this point.
Eventually, I'm looking to move to Nuendo in a full configuration, but there's a new version of Nuendo to be announced in May, and I want to be sure to qualify for a free upgrade, so I'm thinking of getting my DAW feet wet on n-track to start.
I'll be doing about 24 tracks at 96khz or 48 tracks at 48khz in and out at the same time, so I want to be sure I'm not limiting myself with bandwidth. Those are also just the in/out numbers - I want a lot more flexibility inside the DAW at the same time.
I'm very comfortable with roll-your-own PC hardware / bioses/ busses/ device drivers, etc., so I'm prepared for the initial configuration pain. On the other hand, this will be a brand new machine with fresh installs of everything, dedicated to this one purpose, so I have hope of decent stability.
My biggest concerns are with CPU utilization, disk throughput, and PCI bus loading. Right now the configuration I'm considering would be a
- windows xp pro tailored with all the "pretty" stuff turned off
- dual CPU (Probably dual 1.9 ghz Athlon) mboard (probably asus)
- 1 gig registered ddr memory
- 4 hard disks, all Maxtor 80 gb drives
- 1 used as system disk
- 2 used as raid 0 pair with adaptec 2400 controller (uses hardware to control, no CPU overhead) for the actual tracking
- 1 mounted in removable rack and used as a project drive
- matrox dual monitor display (450 or 550)
- 2 Nuendo/RME 96/52 cards for lightpipe input/output
- DVD+RW for backup
After I get that up and running smoothly, I'll start adding plugins to the mix. I'm leaning toward
the UAD-1 card and the Wave Platinum bundle.
Here's hoping I can violate your 32-channel rule of thumb!
Thanks again for your info - greatly appreciated.
-lee-
