malcolm123 said:
			Just and idea as to how many of you are mixing in Parallel or Rectangle rooms with or without Bass Traps.
any comments on the results you are getting are welcomed as well. Also how you may work around low problems if you have any during mixdowns.
Thanks
Malcolm
I think the title / poll question makes an assumption which is not correct.  The assumption is that rooms that don't have parallel walls, don't suffer from room modes.  This is just not the case.  The biggest acoustic factor in all small rooms, below 12,000 cubic feet, are room modes. Angling, tilting, or splaying walls, may help at MID to HF frequencies, by helping to redirect energy away from the monitoring area, but it will not change the problem of room modes.  However, it does make them harder to predict.
Having said that, it is more important do get the ratio of length, to height, to width to be "ideal", along with using LF absorption, to come up with a room that has good LF performance in the monitoring area.  Additionally, using a bass-managed sub/sat monitoring system can also be helpful -
www.abluesky.com/fullrange <---- more information here.
Just for reference, here are some guidelines for room geometries that yield good LF performance.
1 - 	The room ratios should conform to the following equation: 1.1 X W/H is [= to or greater than] L/H [= to or greater than] 4.5 X W/H-4 (sorry could not get the symbols to work right)	(l=length; w=width; h=height)
2 - 	The length or the width should not be greater than 3 times the height.
3 -	The ratio of dimensions should not be in integer multiples.
4 -	The number of modes should increase within a 1/3 octave band with each increase in center frequency.
5-	The room should not have significant overlap of room modes from the three different axes (length, width, height) at any frequency from 20Hz to 150Hz.
*	For a reference, a room that has the following interior dimensions will meet these guidelines. 21x16x9 feet.  This room is about 3k Cubic Feet in volume.
Hope this helps...
