R
RAK
Manufacturer - Shure, Inc
mrface2112 said:what kind of stereo image (and therefore panning) do you really have on a 4-piece kit anyway?![]()
I guess it would depend on how far apart you put your OHs and/or Room Mics.
RAK said:I guess it would depend on how far apart you put your OHs and/or Room Mics.![]()
mrface2112 said:LOL
but think about it.....when you're standing 6ft away in front of a kit, how much L/R is there between the rack tom and the floor tom? do you really need to have the rack tom panned hard L and the floor tom panned hard R?
or at least, when compared to a 12 piece kit with rack toms 6-16in in size?![]()
cheers,
wade
RAK said:Definetly not. I'm with ya.
Of course if a kit doesn't have at least 7 toms and two kicks, I don't bother. I need a cymbal-full field of vision before I can even think about playing.
NL5 said:You'll get the biggest stereo spread with them less than an inch apart............
...X/Y.![]()
most digital multitracks have preamps included....youll need one preamp for each mic you want to use simultaneously so find out how many it has beforehand......adolescentsfan said:Alot of digital multi tracks that I've been looking at say that a mic pre-amp is programmed in so I can make adjustments from there. Does this mean I don't need the mic pre-amp? Any thoughts?
I know this is a little off subject but whenever I try to start a new thread some sort of error occurs. Besides this is my last question. Help me here and I wont bother you again.....for a while.
...X/Y.![]()
boingoman said:You won't get any stereo image at all unless you use the pan knobs.
RAK said:Wouldn't you say you'd get a wider stereo image with a near-coincident pair like ORTF or NOS, as opposed to the tighter image you get with a coincident pair like XY?
NL5 said:I don't us ORTF much, but no, I don't believe it is wider (could be wrong though) - with a standard X/Y you can get drums WAY unaturally wide - don't know why you would want them wider than that. The only way I know of to get a wider spread would be a M/S type deal. Maybe I am doing something wrong, but a wide spaced pair gives me a lot of ambience, but not a clear/wide stereo image.
I dunno?
RAK said:Well an XY configuration is two microphones at a 90 degree angle.
ORTF is 17 CM (or the size of a Frenchman's head, as they say) apart at 110 degrees.
NOS is 30 CM apart at 90 degrees.
ORTF and NOS are considered Near-Coincident pairs. It's not like it's a spaced array or decca tree or anything like that.
One of the reasons that XY fold down into Mono better than the others is because it's a fairly tight pattern.
This would be easier to show with pictures or a hands-on demonstration.
NL5 said:The reason X/Y will fold down better is because it all but eliminates phase issues as the sound waves all reach both mics nearly simultaneously
Maybe we have different definitions of a stereo image, but how do you say a tight pattern like X/Y has a wide stereo image? ORTF and NOS are just variations of the X/Y pattern, but I do consider them as capturing "wider stereo images"- which again is why it has such a clear wide stereo image.
EDIT - Just saw that you are a product developer for Shure - what products?
RAK said:Good point.
And even then, only if you pan one towards L and one towards R.
RAK said:If you had a spaced array of two mics on opposite ends of a 20 foot stage, that would be an extremely wide stereo image, but probably susceptible to lots of phase issues.
to simply this post all the gear you already have and your budget and we will tell you a few options of what to get(we are good at that part) then we can explain how to use everything and what not ... just a suggestion not trying to be mean just make it easier on youNL5 said:I'm not sure what point you are trying to make. I'm a little slow sometimes.
Like I sasid, maybe I am doing something wrong..........
