apl said:
Respectfully, sir, there is a standard for monitoring, used primarily in video and cinema. It would probably help us wankers a lot to adopt it. Massive Master and mshilarious (who is rapidly moving up the list of the smartest people I know) seem to be referencing that standard.
I understand that position, apl.
I also know that many engineers with much more experience than you and I put together undertand that the 85dB "standard" is a theoretical guideline based upon audiology theory. It is to be considered a starting point that is modified by many variables, not the least of which include the performance of the individual's ears, the amount of ambient noise in the listening environment, and the style of audio being engineered.
To say that one
should monitor at 85dBSPL C weighted is tantamount to saying that one
should add a 400Hz cut and a 4k boost to their kick, or that they
should compress their vocal track to achieve a 4-6dB peak reduction. While those are all good general guidelines that can often work well, they are not something that should be considered specifications to be followed without modification or consideration for the content.
For every instance where one reads that "85/C" recommendation, one reads a professional engineer (mixing and/or mastering) who regularly breaks that recommendation. I remember reading in one of Owsinski's "Handbook" series of books, I honestly don't remember for sure if it was the mixing or the mastering one but I belive it was the mixing one (maybe somebidy can look this up for us?) that the A-list engineer being interviewed did all his monitoring at "normal conversation level", which - unless shouting is what this guy considers "normal conversation"
- equates out to a good 20dB (+/-5dB) less than the standard recommendation. And if I had a dollar for the number of times I have read or heard someone with real pro experience on this board (or in magazine or book interviews) recommend that one check their mixes at low volume as well as high volume, I'd be able to go out and get that DM 3200 that I have my eyes on
I know for myself that I do a lot of mixing in the 80-85dBSPL range, but that I also do a lot at something more like 65-70dBSPL or even less. Even when I am up in the 80s, I'll ofen wind up bringing it down 5-10dB after a while because, for my ears, 85dB is LOUD. Not only do I not necessarily have to go that high in order to get the proper bass level as recommended by the Fletcher-Munson curve (a curve, BTW, which is not chiseled in stone, but is different for everybody's ears), but I find that sustained listening at that volume is very fatiguing. My mixes turn out better when I have one hand on the CR volume control than if I decide to follow some theory of averages on a piece of paper.
What I was trying to say with my riff about numbers is, one needs to learn one's ears the same way they need to learn one's monitoring chain. I have a cut-rate SPL meter like everybody else does. When I first got my gear in it's current configuration I did the pink noise measurements and made note of where in my CR volume control that level was located. That was some severn years ago. Other than to occasionaly show others or to just take some test readings at some of my live shows for the hell of it, I have not had that meter out of storage since that time. And while I use that noted point on my volume control as a base reference, I set the volume to what works for my ears on that day with that material.
That is how it works for me and many others, and is, IMHO, how it
should work in general. To say that one
should set their monitoring environment to "X" is one of those generalizations that is a good baseline to work from, but often just does not follow reality any more than any other simplistic "preset" remedy in the engineering chain does. To me the answer is to learn one's monitors and learn one's ears so thay can make mixes and/or masters that translate the best to the greater world. Once you have that fundamental of engineering down, the actual numbers you wind up at are irrelevant to you and not necessarily applicable to your neighbor with different ears in a different situation.
So don't hate me, sir, for calling the Emperors Fletcher and Munson for being only partially clothed. You already hate me for being a Sox fan...isn't that enough?
G.
