T
		The Axis
Member
You make sense Axis.
A lot of sense but does that actually transfer over to the final mix?
This is so true of amp building. It's better to have more gain in the pre ....But their is a saturation point ......
Yup, 60's era designs were frought with all sorts of trade-offs. If you look at most of them, they were only able to claim 20-20kHz response because the response was still within -3 dB at 20 kHz.
A modern solid state design will be within ± 0.2 dB all the way to 60 kHz.
Now, maybe you like the "sound" of certain designs. That is good, but that is all a matter of opinion. I like old fender tube amps. I am not disparaging old designs.
I am pointing out that even cheap modern amps have more accurate transmission and amplification of the signal. They preamp has very little "sound" of its own. that is different than adding an "effect" that you happen to like.
