Fishmed
What specific pre's do you think will degrade a great source/room/well-placed-mic into something that's bad sounding?
Those found on a Behringer DDX-3216.
Um, I think everyone would agree that the preamps in say, a SoundBlaster card are pretty much worse than anything even Behringer makes (or not?). But with a great sounding source in a good room, the recording will still sound good.
Not as good as if you had used a cleaner signal path like a DMP3, or maybe even a really expensive pre, but it will still sound good.
I admit I avoid Behri pre's. But I have tested them and while they may degrade the potential quality more than most, it's still possible to get a good sound through them given a good source, room, the right mic.Those found on a Behringer...![]()
We're not talking about a pre just holding you back. Sure, some pre's will degrade the sound. We're talking about a pre making a track inherently bad sounding. I say no.
Well, duh. I mean ... if the pre is complete dog shit, then yea, it's going to be a spoiler.
But true dog shit pres are actually kind of rare; with Behringer and ART certainly being two that would qualify for that honor.
Mediocrity is pointing at your gear as the culprit ... or thinking that spending money on something is the answer.
Greatness is owning up to your responsibility; holding yourself responsible for getting good sound ... rather than pointing at the gear as either the scapegoat or as the panacea.
With no disrespect intended, I'm wondering how it is you have tried every single one of them ?
Or is their something common among all of them that makes them all dog shit for the same reason ?
Same studio. Mostly ART preamps.
Same producer. You can see he likes a certain "sound".
Well, basically anything by Behringer is going to be complete shit.
And the ARTs that I am specifically refering to are the $30 toys that you can get on clearance from Musicians Assclowns or whatever. Those Tube MP thingies ... as those are the ones that we've been talking about ... only for like the entire thead up to this point.
Dude, can you share the chain used on drums for those sessions?
Drums sound great!
...thus, the 20 bit recordings were truncated to 16 bit)
So, not much time to work with anything. I went with what I knew would work well, but there were some things I would have liked to work on.I kind of have to say this about the behringer mic200. I was able to get a certain bass sound with it that was used in the early 70's. I could not with a sans amp which was touted as being able to get it.
As a DI I was able to get the P bass and farty amp sound when you kind of turn up an Ampeg SVT or V4B, even the B-15. For some reason they fart out a certain way that the MIC200 was able to do. Since I go direct and can not mic a bass amp, I record in my bedroom in an apartment house in new york city.
I could not get the same sound from the SOLO 610 I have.
My point is that certain things even though they are crap, you can get something out of them. It may be only one thing, but that one thing is usable and important.
I use cheap guitars for slide, they sound better for slide then an expensive guitar. In fact the Duncan pickups in the guitar cost more then the guitar, they are Fender Squier 51's I got for $99 each. I would use them to play but they make some awesome slide guitars, along with my Dan electro.
I think the whole thing really is having as many options as possible and knowing what every one of them is best suited for. Like a certain mic will sound better with a preamp that might cost a grand less, it's just the way it is.
That's why I ask about pres because I know that each one will sound different under different conditions.
Having as many flavors and choices and knowing how to use them is the way to go. Not only as you record but in the final mix. Like choosing the right mic for certain vocalists, then the best pre to get the best sound and so on. It's all about the chain.
That can be said about the guitar, pedal, amp speaker chain. The mic, board, processor, box, speaker in a sound system. So recording is no different in that particular equation. Knowing that equation gives you the best knowledge of your palet as an artist, that's the engineering artist interface.
