			Seeker of Rock
Seeker-Lou ‘32
There is a formula, I believe on Ethan's site and others will probably be able to cite it verbatim.  I think it is 60 degree angle or something to your ears.  In other words, if the near fields are spread too far, you will have to angle them at extremes to aim toward your ears, so maybe wider is not better.  I think mine are about 5' apart and angled toward my ears, FWIW.  Technically, I'm sure everything with a hard surface in your control room will have a reflection of some sort, including hard parts of your chair like the base/legs, mixing desk, console legs, doorknobs, buttons on your shirt or jewelry around your neck, etc.  If reflections from the desk platform were a problem, you could always use something like a rubber matt or even foam (which may look kind of cool if done right) in the empty areas not taken up by the mixing board.
		 . I think it might be something to do will stopping the bass frequencies which come out the back of the speaker. Also, i think, if built properly, it isolates the speakers from the rest of the room, so the bass frquencies don't vibrate through the desk/walls etc and reach your ears before the airbourn sounds. Not sure though...
