peritus
The not fountain head
http://ultravnc.sourceforge.net/ + Laptop
Treeline said:Here's a way you can run things from a vocal booth and avoid the keyboard / extension cord thing. The unit works remotely and is not limited to line of sight. So you could keep the vocal booth area separate and still control things from within it.
Frontier TranzPort It's available for about $200.
[Edit]: I note CincyKid beat me to it...![]()
peritus said:
Sorry been away at a folk festival. Other 2 things are computer monitors. It isn't necessary but it would mean it is more semetrical, ie better acoustically.cincy_kid said:heya Panda, we meet again!![]()
Thanks for the reply.
Is the extra countertop install necessary? It was a pain hehe. I like your placement of absorbers however and even the monitor placement. Whats the other 2 things on the front counter?
Thanks again
you're right, either miing board, or a desk for a mixer.peritus said:Plus, if someday you got a big mixing board.. You'd be ready...(which appears to be that black rectangle in Panda's version)...
.. I wanna see...JeffLancaster said:Hey Cincy, why do the panels HAVE to be 8'? Can't you just make them the height you need so they don't have to slant? Also, how about somehow designing them as interlocking panels with MDF on the back - seems like that should help cut sound transmission to some extent (although they'd be heavy panels). For the windows, how about making gasketed plugs out of MDF? Also, if you have a hollow door leading into the room, perhaps you could consider replacing it with a solid one, with "weatherstripping".
JeffLancaster said:Also, how about somehow designing them as interlocking panels with MDF on the back - seems like that should help cut sound transmission to some extent (although they'd be heavy panels).
JeffLancaster said:For the windows, how about making gasketed plugs out of MDF?.
JeffLancaster said:Also, if you have a hollow door leading into the room, perhaps you could consider replacing it with a solid one, with "weatherstripping".
peritus said:I wouldn't put any mdf on the back.. You want the sound to go in to the "trap", bounce off the wall and return, attenuated....
You could cut 3/4" MDF to fit either inside or over the window frames, with weatherstripping to ask as a gasket when it is pressed into place. You would need some sort of latches that keep the plugs in place with the weatherstipping tightly compressed. But again, this is only necessary if you're trying to soundproof the room. Personally, I like to be able to record without capturing the sounds of the idiots out there squealing their tires up and down the street, but that's just mecincy_kid said:I have no idea what you mean here. Could you elaborate?
You must not have any little kids screaming and yelling in the hall, or a wife who gets upset if you make noise late at nightcincy_kid said:Not worried about soundproofing and wont mess with the door for now but thx for the suggestion
peritus said:Okay.. Ya ever see bifold doors... like in a closet?
Like these:
How about:
Create four identical (floor to "duct" ceiling height) panels of fabric 703.... Build a frame for them out of 1x4 or somethin... (Cut the 703 outside..)
Okay.. Use parts from here, for the track, etc.:
http://www.johnsonhardware.com/1700sm.htm
Hmm... make sure you leave room to fold...
As Ethan describes:
"There are a number of ways to create a bass trap. The simplest and least expensive is to install a large amount of thick rigid fiberglass, spacing it well away from the wall or ceiling. As noted earlier, 705-FRK that is four inches thick and spaced 16 inches away from the wall can be quite effective to frequencies below 125 Hz. But many rooms have severe problems far below 125 Hz and losing twenty inches all around the room for thick fiberglass and a large air space is unacceptable to most studio owners and audiophiles. Fortunately, more efficient bass trap designs are available that are much smaller. However, studios on a tight budget can apply rigid fiberglass in the room corners as shown in Figure 3a and lose only the small amount of space in the corners. Since bass builds up the most in the corners of a room, this is an ideal location for any bass trap. Top
Just a thought.. Plus I think it'd be an attractive-looking option...
