your timing jumps in and out, if it's because of the delay thing it should be relatively simple to slide the track forward a few milliseconds. i guess that depends on what gear you're using and if you have that capability. i'm into most any style of music, and if a song/track is good despite a bad recording i can live with it, but offtime playing just puts me off. you have some cool sounds, but they need to be balanced and EQ'd a lot better. i could take your drumtracks and make them POP, and so can you. try to get rid of the muffled sound and maybe use some compression & volume to make the drums jump out. mixed the way it is, it reminds me of Ween's "The Pod" album, but without the charm. that album sounds the way it does because they did the whole thing on a cheap 4-track with low-bias tape. i hope you're using something a little better than that, but if not, you can work with it. keep at it!
