help ..........
  • Thread starter Thread starter royalb
R
royalb
hello
what mic should i buy??????
i want to record vocals only(more male than female) using a 737 pre
$2000-6000 price range .....
(hiphop)end of the world sound is what im looking for...lol
what should i do...anyone
thanks
paul
If you have $2000, go to a studio and record. Whatever mic they use (and you like) buy it. This is only the tip of the iceberg!
- mic placement
- room treatment
-tracking
-editing
-eq
-compression
-mixing
-mastering
-finalizing
-blah, blah, blah
that's a LOT of money to spend on a mic if you don't really know what you're looking for.
the suggestion about going to a studio for a few hrs and trying out all their mics is a great idea. you wouldn't need that much time either, just a few hours, throw up some mics, record 2 mins of the same song into each mic, and then A/B 'em.
what other equipment do you have? remember, your signal chain is only as strong as it's weakest link. there's no point blowing $6k on a mic and have some shitty-ass preamps eating up all that nice sound. maybe you want to considering buying a less expensive mic and getting a nice tube pre-amp? just a thought..
EDIT: just re-read your post and saw the bit about you're pre. seems you've got that end covered!
If you can't make a rapper sound good through a $1000 mic, it ain't gonna happen by adding more G's. I'd suggest you audition several mics and pick the one that sounds best with your pre. It's the only way to make the wisest decision.
You will however need a $5000 pop filter which I happen to have for sale. :D
Man, even a Studio projects C1 will do good for you! Are you really that professional to buy a $6000 mic, cause then it would sound somewhat logical.
Hey Paul,
Well, first an observation, then a suggestion.
Since IMHO, the essence and main focus of rap recordings is the story being told, and the story being told is mostly rhythmic spoken word surrounded with cool, quirky rhythmic sounds and music, I'd be looking at mics that tend to emphasize the frequencies that make the spoken word sit out front of the sounds and music accompanying the spoken word.
Sounds simple, but things that appear simple aren't always easy. As an example... what type of voice do you have? Is it low and deep, high and bright, mid-rangy, etc.?
Also, how would you describe the tonal character of the sounds and music that accompany the voice? Do these accompanying sounds and music tend to occupy the same frequency range as the voice? These are just a few things to consider.
In the studio, you're not usually faced with feedback or bleed issues compared to doing live performances, so you can usually choose from a greater number of mics.
There are lots of dynamic and condenser mics that have "tailored" midrange and upper mids to help a vocal "cut" through other instruments. The Shure SM-57 and SM-58 (both dynamic mics, less than $150 each) fall into this catagory. The Studio Projects C1 (LD condenser, less than $300) might also fall into this catagory. Lots of other mics do too.
The preamp and other components of the recording chain will influence how the vocal sits in a mix, including the EQ and the "placement" of the tracks in a mix itself. If you have a friend or local music store that will let you try a bunch of mics before you buy, you can compare and decide which mic sounds the best with your voice and style.
What works well for one artist may not work for another. Also, a "high price" doesn't always mean "better sounding". Let your ears be your guide.
Good luck!
