			undrgrnd studio
I could use some assistance in determining what gear to use for my studio.  I have been fairly happy with the way I have it set up, but I just got some new gear and thought it would be a good time to reassess what gear I am using for what purpose.
Tonight I will be recording a full band. I basically direct in the guitar and bass, have the singer on a scratch track and then keep the drum and bass take, with occasional punch ins on bass. Then the guitars and vocals get re tracked. This is typical of how I use the studio.
The way it is currently set up is.
Drums Setup:
SP B1 mic approximately 3 feet above snare/hi hat/crash section.
Going through an M-Audio DMP-3.
M-Audio Nova 3 feet above the ride/floor tom area.
Through DMP-3
SM 57 pointed at snare 3 inches away.
M-Audio Audio Buddy preamp.
SM 57 6 inches away slight off center from sound hole in front of kick drum
Bellari MP-105 mic pre with telefunken tube and upgraded opamaps and pots.
Guitar Setup:
SM 57 - directly in front of two 12" 70's tuck n roll Kustom speaker cab, Fender 100 watt head.
Rane MS1-B.
Bass Setup:
Modded P Bass, direct into ART MPA Gold, upgraded tubes.
Vocals Setup:
AT 4040
Symetrix 525 compressor, Art MPA Gold, upgraded tubes.
I have new gear as of this week. This is what I have at my disposal now.
Mics:
AT4040, M-Audio Luna, M-Audio Nova, Studio Projects B-1, SM 58, 3 SM 57’s, Shure Unidyne, 2 misc crappy dynamics
Mic Pres:
Art MPA Gold Swapped tubes, Art Digital MPA II swapped tubes, M-Audio DMP-3, M-Audio audio buddy, Bellari MP-105 modded, Rane MS 1B, 2 ART Tube MPs
Compression:
FMR RNC, Symetrix 525, Alesis NanoCompressor
Amps:
Tubeworks tubedriver, Fender 100 watt with 2X12 Kustom, SWR Working pro 300 with 2X10 Genz Benz.
So basically I was wondering if any of you had specific suggestion on what gear to use with what?
Drums Setup:
Through DMP-3
Guitar Setup:
Rane MS1-B.
Bass Setup:
Vocals Setup:
AT 4040
Mics:
Mic Pres:
Compression:
Amps:
