muttley600
Banned
Do you think there is something in particular I should be checking on the bridge end?
Essentially it just needs to be secured well. All the screws on the bridge and saddles need to be tight with the string not obstructed. There isn't a lot else to worry about.
Frankly it sounds to me as if this might have been a one off and haopened as a result of something that has now settled. Give the guitar a good look over a and try and spot anything that maybe loose. Other than that keep an eye on it and if it happens again we can look into other possible causes.
I can pretty much guarantee that it is not to do with your tuners. Despite what others are saying tuners just don't do that. If and when it does happen the first place to look is the nut and the second is the saddle. That is assuming that you have a minimum of two turns on each string. After that you need to look at the string itself if is it is only one string. If it is more than one string then the cause would likely be found elsewhere.
