Why not use stands?Bdrum said:I'm looking for some tom mic mounts that will hold sm57's and will not move!!!!!!
I've tried two different ones and they just piss me off@#@!#!$)(!!
A limiter won't do anything about this. You need a low pass filter.jaykeMURD said:you may have to use a limiter to cut off the "vibrations" the clip will pick up and transfer to the mic from the resonating shell/rim.
Thunder33 said:I have some that are great. I believe they are called Claws. I will see if I can find you some info. They are pricey though.
Bdrum said:Hey, if they work It would be much of a relief.
I've used the AKG 418 series and cried like a baby when it got broke.
I like my friends Audix set but I would rather break a 57
ckent said:One thing I didn't try, but might work: use a shock mount on something like the Claw. Hopefully that would reduce transmitted vibrations.
Note--you can get a cheap mic stand for about the same street price ($25) as the Mic Claw.
Alan
