HELP NEEDED using a mixer
  • Thread starter Thread starter kurtoxic
K
kurtoxic
So i recently bought a yamaha MG12/4 mixer to record on my computer via the record out on the board and the mic in on the computer. When i hit record on the cool edit pro program with the tracks in stereo and i try to pan the mic left or right it doesn't do anything. Infact when i pan to the right 100% no signal is recorded at all. I can see the panning is working fine on the board due to the levels bar. It just isnt going to the computer panned. Oh also i do have a stereo cable plugging the computer and mixer. Am i doing somthing wrong? Any ideas?. Thanks
what kind of sound card do you have? have you checked the cable.. what kind of cable are you using.. I remember once i tried using on of those cables to branch out into 2 /4" inputs and it didn't work at all the way i thought... I've had success with cable that plugs into a sound card and has rca ins on the other end.. then you plug that into the rca out on your mixer. should work.
if not then i'm not sure at all
use the line in, not the mic in on your computer. The mic jack is probably mono.
