Help me!!! I'm We-Todd-Ed!!
  • Thread starter Thread starter Kingofpain678
Well, you could use ReaXComp. That has and unlimited amount of bands and the ratio goes to 100. From what I've learned, anything over 10 is basically working as a limiter.
The HP/LP in ReaComp only tells the compressor where to look for peaks, but if I remember right, the entire signal still gets compressed.
P.S. thanks for the kind words. Just trying to help out where I can :)
The compressor that came with Reaper (I have an old version still) has a ratio that goes to infinity (like a limiter) and has a selectable band. I suppose if you wanted to make it work on more than one band, you could setup more than one compressor.
i can't seem to find any of the generic reaper plugs... i must not have installed them correctly? :confused:
So basically any compressor that goes to infinity can be used as a limiter?
wierd. When I got Reaper, it came with dozens of plugins. I believe a limiter is basically just a compressor with really high compression ratio.
This isn't multiband, but here is a good free limiter... http://www.yohng.com/w1limit.html
Yeah, I'm thinking that I must have installed it wrong :confused:
The good news is, I went on a VST hunt when i got reaper and I do have a multi band compressor with a ratio that can go to 10:1 so if a 10:1 ratio on a comp does indeed act as a limiter I believe I should be safe.
Run the installer again and make sure the "Audio processing plugins" box is checked. No need to uninstall first either :)
In REAPER's FX browser, there should be a Cockos category and a JS category. The Cockos ones are the ReaPlugs (ie: ReaXComp their multiband compressor)
