Matt Beddall
If your both singing at the same time in the same room you will probably get overspill into each others mic so you would both need to nail the same take or something might sound a bit off
If your singing harmonies it's always worth trying both singing into the same mic, sometimes you just get a more naturally glued together feel that way.
Another trick is to each put an earplug in one ear, you will both be able to hear your own voice a little bit more and you can wear headphones over the top, it will make it a little easier for you to both live with the same cue mix
