Headphone correction with a console
FrankD77
FrankD77
Active member
I've seen a lot of adds for headphone correction software.
I also see large consoles in the back and that raises a question. I'm using an x32 and use the internal recorder and part of FX. So my headphones are connected to the x32. As far as I can figure out this will not work with the correction software because i don't want the correction in my recording and connecting the headphones on the desktop means I'm missing the whole FX chain.
So do they just use their consoles as controle interfaces ?
Or do i miss something.
They use their daw as the mixer with an interface and the console in control surface mode with midi over Ethernet. But headphone correction software works for some but not with all people. Mix with 600 ohm headphones and you don't have to use an EQ correction for the impedance mismatch on the headphone amp. I use beyerdynamic DT880 600 ohm headphones and they translate well for me.
Although my room is far from perfect i still prefer the Adams. I do check with headphones later in the process.
It would be nice if you could upload the eq curve into the headphones ;)
