F
foreverain4
has anyone ever installed a hardwood floor over carpet?
You can buy 1-1/8" plywood flooring underlayment that is already T-G. It's not very pretty - would need something on top to finish it off.foreverain4 said:i was actually thinking of using 4x8 ft sheets of maple plywood. i would machine toungue and groove myself.
How do you "fasten" a floor to carpet?f you just constructed a totally new frame fastened to the carpet,
RICK FITZPATRICK said:Is this going to cover the WHOLE floor or just a portion? If the whole floor, why don't you just remove the carpet?
foreverain4 said:i probably wont be covering the whole floor. also, i want to leave the carpet for after i move on....
Nevermind
Surely you jest! Ha Ha. I meant that he could use some kind of brackets or something to keep the new floor frame secured to the existing floor (under the carpet) thus decreasing the possibility of movement an noise when walking or playing drums or something. It wasn't as good a suggestion as simply removing the carpet and saving it for reinstallation later but, I figured he already ruled that out. An enlarged drum riser type of solution was instantly what I thought of.RICK FITZPATRICK said:How do you "fasten" a floor to carpet?![]()
Gotta have some fun around here once in a while...all work no play makes...nevermind
