Hard Drive Probs
  • Thread starter Thread starter GraceTech
G
GraceTech
Hi All
I have a HD24 XR ADAT recorder. I bought a Western Digital 80gig hard drive to use with it and I cannot get the ADAT to recognize the HD. Each time I try to load the HD it gives me a jumper error. The HD needs to be set to master, and it is. I have also tried it on the other settings, slave, cable select, as well. I have also tried a different brand HD (hitachi) and had the same problem. any ideas?
Thanks!
Eric
GraceTech said:
Hi All
There have been lots of discussions of hard disk issues on the HD24 group on Yahoo. Western Digital drives, especially newer ones, have triggered this problem for a sizeable number of users. I've never heard of anyone having trouble with Hitachi, but it's not a very common drive, so it may just not have come up in conversation.
If your drive has a jumper setting for Master with no slave, try that. On some drives, you indicate it by removing all selection jumpers. But based on the last WD drive that I tried, you may have to return it and get a different brand. A lot of people like Seagates.
Good to know others have had an issue with WD HD's and its not just me :o I went online and found more jumper settings than what they say on the HD from WD and I did try pretty much every jumper setting the had just to see if I could get it to work.
I will go out and get a Seagate.
Thanks for your help!
Eric
I too have had this problem. HD set to master but everytime I load it I get an error message regarding jumper failure. Really sucks. Western Digital. Try just to keep loading it and have another "good" HD in the other bay,then copy all off western.
