D
dyuob
I don't know if any one else has done this, but if you print out the MR 8 manual, (from the pdf file) and put it in a 3 ring binder, it is actually easier to read than the original manual that comes with the unit. It is a bigger page, some stuff is in color, and the pages lay flat if you need them to.
I've got mine in a one inch binder, and it holds the whole manual, all the pdf brochures, as well as all the update print outs with no problem. It also has the clear plastic on the front so you can slip a picture in there as well, I've got the manual cover printed out and inserted there.
Like I said, it lays flat, which really comes in handy at times.
