P
Phyl
Guest
I came across the following paragraph while researching info on desk and monitor placement:
'Remember too that cables are directional. Sometimes this is because the connections differ at each end (some designs leave "ground" unconnected at one end to minimize noise transfer). Even if the connections are the same at both ends, all cables will become directional once they've been used long enough to break-in. Some manufacturers put arrows on the cable or on the connectors to help with proper orientation. When I start using a cable without arrows, I orient it so any writing on the jacket follows the direction of signal flow.'
For more enlightening info:
http://www.barrydiamentaudio.com/monitoring.htm
I read everything on his whole site.
