O
Obstacle1
Anyone know if this means its fucked, or can this be fixed and could i do it, or would it be best to have a pro look at it?
Obstacle1 said:Anyone know if this means its fucked, or can this be fixed and could i do it, or would it be best to have a pro look at it?
Obstacle1 said:Okay - i'll look into shielding and grounding - thanks alot MCI2424
Obstacle1 said:It is... is this typical with tele's?
Obstacle1 said:okay - well i have a noise suppresor on my boss multi-effects but can't seem to figure it out - it has no guide on the knobs, i'll wait for telepaul's advice then - thanks alot
pdadda said:I have a 72' Deluxe RI Tele, and I have the same problem. Mine has humbuckers too.
Anfontan said:You most definitely have a ground problem there, it should be almost dead quiet with Humbuckers in it. Doesn't it have volume & tones controls for both pickups and a 3 way Gibson style toggle switch like a Les Paul? These should - I believe - have a wire grounding the control pots to the bridge, a standard Tele with single coils is grounded that way I know. This schematic should roughly be what your guitar's electronics look like~
Tele Deluxe with 2 H'buckers
TelePaul said:How bout on standard Teles? Is the gorund hum normal? Are the red and white wires the grounding?
Anfontan said:Yeah, on a standard 2 wire single coil you are going to get that hum. About all you can do is to find the spot in the room that is less susceptible to that hum. I sometimes have to turn several ways to find that quiet spot when I record with my Tele with single coils in it. At gigs I don't have a problem, I can be far enough away from the amp its not too bad.
And like I've said before-Dimarzio makes some nice single coil sized humbuckers for Teles-I like them a lot!
Wiring for standard 2 wire Teles
Obstacle1 said:Yeah TelePaul my NS does have a threshold knob (its a Boss ME-20), can you explain what i need to do with the NS - the manual given says very little about how to use it. Thanks,
Anfontman - so changing pickups should help the grounding issue?
Anfontan said:No, if you are using 2 humbuckers I believe its in the wiring. The pickups are probably just fine, a bad ground WILL cause a horrible buzz in the system. I had a buzz in a Tele that was the volume pot not having a good ground, after I redid the connection with good rosin core solder & a bit of flux it quieted it totally!
