A
ADATlove
I have been using a modern Behringer mixer, which is grounded, and every 20 mnutes or so I experience a power surge which is probably caused by the AC kicking in. I just swapped the Behringer out for a Tascam M320B, which is not grounded, and the surges that used to result only in a slightly dimmed light and an indication on my power conditioner, now give me a pretty bad hum. I tried a few things to narrow the problem and it appears as though the hum only comes through the main L/R bus. So when I'm in the "hum period" and I switch into solo mode I get no hum.
What can I do to fix this? Is it a grounding issue or am I barking up the wrong tree entirely? Can I merely install a new power cord that is grounded by just touching the ground wire to the Tascam's metal chasis?
Thanks for your help!
