Ok here's my advice.
Guitars = Cut or boost the lows if its sounds good to your ears, or maybe cut or boost the mids if it sounds good, or the highs if that sounds good. Or maybe a combination if it if it sounds good. The cuts/boost should be somewhere between 20hz and 40khz. You might want to use some compression, but then equally you might not.
Bass = Cut or boost the lows if its sounds good to your ears, or maybe cut or boost the mids if it sounds good, or the highs if that sounds good. Or maybe a combination if it if it sounds good. The cuts/boost should be somewhere between 20hz and 40khz. You might want to use some compression, but then equally you might not.
Drums = For each piece, cut or boost the lows if its sounds good to your ears, or maybe cut or boost the mids if it sounds good, or the highs if that sounds good. Or maybe a combination if it if it sounds good. The cuts/vocals should be somewhere between 20hz and 40khz. You might want to use some compression, but then equally you might not.
Vocals = Cut or boost the lows if its sounds good to your ears, or maybe cut or boost the mids if it sounds good, or the highs if that sounds good. Or maybe a combination if it if it sounds good. The cuts/vocals should be somewhere between 20hz and 40khz. You might want to use some compression, but then equally you might not.
