Glass window between control room / live room
  • Thread starter Thread starter djgc
Regardless of wether the angle helps with the sound isolation, I also thought that angling the glass helps with the actual room acoustic as you don't have a large reflective surface parallel to the wall. The angle of the glass will act as a defuser.
Cheers
Alan.
Alan,
Myth......... that is unless you have one hell of a tilt in your window......
the angling of walls help to deal with flutter echo and (perhaps) first reflections (if they are done right) - by done right I mean that the total of the 2 surfaces need to have a minimum total of 12 degrees of variance between them.
So for a window to correct for a back wall that would be parallel to the window if the window were installed plumb - that would mean the window would have to be installed 12 degrees out of plumb.......
For a window opening 4' in height that would translate to the window pane having to tilt into the room 10 3/16" from top to bottom........ 7 5/8" for a 3' tall window...
that is some serious tilt - it would require 2x12 walls for a 4' window and at least 2x8 walls for a 3' tall window - and (to be totally honest with you) I have never in over 33 years in this industry ever seen a window in a studio installed with that large a tilt in the glass.........
If this was something you were really seriously concerned with - it would be much easier to deal with a the back wall with a combinations of absorption and diffusion.
Rod
Oh well Mine has been built for years, it works for me, and that was all I was saying in my 1st post, it was an example of how well it worked.
I am not saying that the glass has to be at an angle, but almost every studio I have been in or seen photos of have angled glass, I have read (acoustics 101 site) that if it is less than 8 deg then you are wasting your time, well mine is at about 8 deg.
I am not saying you are wrong, but how is it that almost every recording studio in the world has glass at an angle?
Cheers
Alan.
Cheers
Alan.
Alan,
you assume to much - I am in no way saying that it is wrong to do this.......
We are speaking here strictly about science - the law of physics - which has nothing in the world to do with anything other than that subject.
I am a published author in the field - in my book I provide details for sloped glass windows as well as parallel.
I explain the actual physics involved - and then suggest that they do it with sloped glass because it is just too cool looking to do it any other way.... and because (as I noted in an earlier post I made in this thread) once you have enough mass in one side of the assembly, coupled with a slight difference in thickness to handle coincidence in the other - the added mass makes up for the small loss in isolation.........
Every recording studio I have ever designed had sloping glass in it - and every one I design from this point forward (for as long as I am able to design studios) will have sloped glass in it......
I am not saying that anyone is wrong for putting glass in a studio out of plumb........ however let's at least do it for the right (hence "real") reasons - acoustic myths like this need to be proven for what they are....... they don't even reach the level of quasi-science.......
Rod, It's all interesting, I did not really have an opinion either way, but it does look cool to have angled glass ha ha. All the studio books and articles I have read always have angled glass so thats how I built mine.
Buy the way, a few years ago I was involved in designing a community radio station, I specified double glass in all the windows but to save space and money we used off the shelf commercial made double glazed windows. As we were only trying to keep out people taking in the next studio or lounge, not a band playing, it works fine.
Thanks for your views.
Alan.
So should a vacuum be created between the panes? How do you stop the sound coming through?
No. That is impossible with de-coupled frames. In fact, even if you used a single welded frame, the more vacume you apply, the more probability of glass fracture...unless of course the glass is a calculated thickness..which I doubt you could afford.
By virtue of Physics. MASS.
I’ve actually helped out on a couple of studio builds, and honestly, the whole question of tilting the glass comes up every time. From what I’ve seen, making panes with different thicknesses matters way more for isolation than angling the glass. Most people I know just keep the window straight because it’s easier to frame and you lose less air gap, which is more important for bass isolation. Angling seems to be more about avoiding light reflections and not having parallel reflective surfaces shooting sound straight back, but it doesn’t make a huge difference compared to getting your wall mass and air space right.
Now that VERY decent USB cameras are but a few $$s and you can pick up S/H FSTVs for just a few more I would say back to back tellies and cameras would be cheaper than a really good DG installation and zero sound transmission and no rattles or reflections.
The small local studio I was last in had the control room in a conservatory extension, with a regular domestic sliding double-glazed door to the live room.
The only large pro studio I've been in had a relatively small isolation window to their live room. The effect of the window was insignificant for the space.
What you need is thick laminated glass, a good inch or more thick.
The window doesn't need to be bigger than say a 50" TV.
My last employer fitted such windows, not for audio, but for security.
One of the directors needed to trim the size of one of the thick panes, so he cut a slice off using a regular hand held jig-saw.
Also, one feature I’d seriously consider if doing a window again is using a switchable window film. It lets you keep eye contact when you want or have instant privacy with a button, which is way cooler than an old-school curtain or blind.
