D
djgc
I was wondering if the glass HAS to be tilted at an angle to treat the reflection of sound or can it just be straight where I can just put some absorbing material behind myself to absorb the reflections?
If you are between the glass and the absorber behind you...how would the absorber prevent the reflected sound from reaching your ears first?where I can just put some absorbing material behind myself to absorb the reflections?
oh ya true thatIf you are between the glass and the absorber behind you...how would the absorber prevent the reflected sound from reaching your ears first?![]()
So i will be installing 2 glasses in total. One on each end of the room.
"Fairly thick enough" means nothing. What tells you this is fact. This is why.I forgot the thickness of the glasses but its fairly thick enough to soundproof
What you will also notice however is that the panes are all set at different angles, and none are vertical. Surely there has to be a good reason for this?
One possible reason is that somehow it improves the sound isolation capabilities of the window. The theory is that there could be standing waves between the glass caused by the direct reflection back and forth. However, BBC research has shown that there is virtually no advantage of angling the panes with respect to sound isolation.
The difference it does make however is in the control room and recording areas individually. Flat surfaces are always acoustically disastrous as they cause strong reflections that are not dispersed. And of course windows are always flat, and tend to be large. So it is in fact a good idea to consider where this reflection is going, and preferably the outer panes will be angled so that sound is reflected towards absorbent or diffusing acoustic treatment.
Also there is a purely visual aspect. Vertical panes create light reflections that travel directly back to whoever is looking through the window. And three thick panes mean there are six surfaces where reflections will occur. So the seeing through a window with three thick, vertical panes is not exactly clear. But if the panes are angled, then the light reflections are directed away from the observer. Consequently the view can be almost as clear as if the panes were not there.
So, angling the panes does not affect sound proofing, but for both acoustic and light reflections it is very worthwhile.
Studio Control Room WindowThis is a hotly debated topic, with several points being debated by experts everywhere. These include questions of expensive laminated glass –vs.– lower cost conventional glass, angling of one side of the window to reduce standing waves between the panes, and general questions of what criteria should be targeted to maintain the performance of the walls. Let’s look at the factual side of each of these points one at a time.
Angled windows or straight? Many sources recommend angling one of the window panes to eliminate internal standing waves and/or to reduce direct reflections from the window.
We can’t help you with the question of acoustics and reflections, but we can offer this certainty: while the angled window may help somewhat with standing waves inside the air cavity, standing waves will still occur. And angling the window will always result in a smaller net air space, which will have a negative effect on low frequency performance. How much of a negative effect depends on how much of the net air volume between the panes of glass is lost. Depending upon how much low frequency content is present in the music, it is very likely that the isolation of a window will be maximized without angled glass.
NonsenseThe glass is slanted to to prevent (or try to) standing waves between the panes to keep the glass from vibrating.
Also, two different thickness panes can help with this.
Why do you need to see at all? I do well enough without window or monitor.coz i like seeing the personinstead of lookin at the person through a monitor.
This is a myth.The glass is slanted to to prevent (or try to) standing waves between the panes to keep the glass from vibrating.
Whew!! Thought I was gonna have to go it alone on this one.This is a myth.
This is a myth.
Thanks John,
I should also have pointed out that the internal distance between the glass is about 8" at the narrowest point, as I have seen some with a gap of only an inch or 2 and I don't believe this is as effective.
Cheers
Alan.
Furthermore, let me quote contridicting opinions from here:
