Does it sound like crap on it's own in the room, or like crap on the recording, or both? There are big differences.
If you don't like the way it sounds live, in the room, then tune it differently or use a different snare. Try different heads. Keep in mind though that the drummer is a member of the band too, and it's ultimately his sound. If he doesn't tell you how to play guitar or bass or sing, leave him alone about his snare. Tight snares play and feel differently than looser snares and maybe that's the feel he likes. If you think you can change his mind, give it a try. I'm personally open to drum suggestions from my bandmates, but that doesn't mean I follow them. You gotta be careful here.
If you like the way it sounds when you play live, but not recorded, then it's your miking technique and/or room and/or equipment. It's tricky capturing the true sound of anything, nevermind a banging snare drum. Keep experimenting with different mics, if you have them, and mic placement. Snares like EQ and compression. And keep in mind that you listen to thrash metal and are looking for "that" snare sound. There's not much natural happening with drum tracks from that genre. Sample replacement very likely in everything you listen to. That sound you're trying to emulate is probably a sample recorded in ideal conditions with ideal mics with and ideal drum. Do it if you want to and your drummer doesn't mind..
