O
omnipotent
"HAY, HAY, HAY, HAY, KIDS" (sorry just seen simpsons)
To get the perfect Bass is probobly imposible but here is some food for thought.
Obviously you need a good bass player, with a good sounding bass. If you cant get this first part right, give up. You cant change an apple into an orange.
Now, normaly I put bass into a DI of some sort. Sansamp Bass Driver DI does the trick. But I have had some awsome results going strait into a Jomeek compresor (I'm sure any compressor might work). Also if i were to mic, i would run the bass into a DI, into a mixer, and finaly into a full size speaker (like ones used in conserts), then i would mic this similar to a bass drum. I find this gives a more real affect, like in a consert.
However if you are totaly happy with the sound you get from your bass amp, the best thing you can do is find a totaly flat mic, with a large frequency range.
Just my two cents,
Best to you all,
Cheers,
omnipotent
[This message has been edited by omnipotent (edited 06-16-2000).]
Just my two cents,
Best to you all,
Cheers,
omnipotent
