Gate for rhytm metal guitar
Miravsky
Hi people, can you tell me what value need to be set in gate plugin for metal guitar. I have Audiotrack waves gate plugin and I have 4 value in it: Treshold, Floor, Attack, Realese.
Thanks for help!
Any gate level is dependent on what you want to exclude from your playing. If it is to be used to keep low level errant sounds out of the recording, set a level which just allows what you want by. Also bear in mind when finding that level any reverb of note decays should be looked at so that your gate is not chopping them off before the desired sounds have ceased.
Regards
Tim
Seven.
Instead of using a gate plug-in....try using this tool in the DAW.....
.....followed by a short fade-out.
I agree. You're just gonna have to man up and spend the time manually cutting all the excess stuff out of there. It sucks, but the results are worth it. If you listen to something like a Disturbed record, you can be sure that it isn't just a tweaked gate on those guitars.
EEEEEWWWWWWWWWW.
