StonedSunset
I have just found out i won the bid on a house and can truly start thinking about building my studio in the extra garage out back of this place. first off, i have a budget, i'm not sure what it is until my wife checks out the finances, but she said i have to, "do it right the first time as cheap as you can." the garage is brand new construction, i don't have the exact measurements right now but it's a standard two-car, the measurements will be posted shortly. but this place doesn't even have the floor in it yet. right now its a sandbox with walls. the plan as of now is to pour concrete my understanding is that that is a good place to start. there is no wiring of any sort yet, the whole house was very recently equipped with clean 200 amp service, and has already dug a wire to deliver power to the garage. that being said, the garage is pretty close to the house and the neighbors houses, so i need to soundproof the hell out of this thing cheaply. it's also Michigan and we will only have space-heaters the the winter. i already have a good friend with a drywall business who said he has special drywall for sound dampening and absorption, but i don't know what kind of insulation i need to have in the exterior walls.its built using trusses, so the ceiling is high, but i'm not sure if it is possible to work around the trusses to use the angle of the ceiling (i would appreciate any thoughts on this especially
), but even if i was limited to a flat ceiling, it's 8 feet tall at least. there are no windows and two steel entry doors as well as the big garage door.i would like to design the studio in a way we can use the garage door to load equipment through still, but i dont know if it's insulated or not.i think you pretty much know as much as i do at this point. please if you took the time to read this give me a suggestion or two. i really need to do this right. i will post more as the planning moves along and as soon as i have the measurements ill put them up with sketch or something. thanks
Or a shuttle takeoff. When you begin to understand this principle, then you might begin to research TRANSMISSION LOSS.
. thank you for the pictures of your space too dude!
