E
ecc83
Ok,
Attached is a record/play noise plot for the KA6 done in Samplitude SE8. 24bits 44.1kHz and all gains were at minimum, inputs open circuit.
You can "calibrate" the plots by the internally generated tone at -18dBFS.
There is also a grab of the Samplitude meter. I have had to tweak the gain by ~2dB because the range stops at -90dB . The actual rms noise is: Left -102, Right -101 and these are of course unweighted figures.
These recordings were done on my HP i3 W7/64 laptop but a quick check on a W7 64 bit desktop showed the same results.
Of greater importance to me, more so than the low inherent noise, is the total absence of artifacts. Very commonly with cheap USB devices you see spikes popping up all over the shop!
Dave. Right! You've seen mine. Let's see yours!!!
