found my dog with my wife...................
  • Thread starter Thread starter videodrone
I don't EQ my amp like that (although I remember reading some BS along those lines). I did play around with the GT-6 before my pre-amp for a while, and decided I get a better sound after the pre and I can use the volume as a master volume. Othere things I did was decide for the most part to use distortion from my boogie, which does really well with overdrive. Also, I set some of my main programs where the CTL button on the right turns on and off the wah wah. Otherwise, going to wah, you have to turn the pedal volume all the way up to push that button.
The GT-6 is versatile and due to it's EQ and pre-amp section, you can add great sound or over process quickly. So I also have most effects and EQ not at 100%.
I also live by the noise supressor, always left on.
Play with the GT-6, it is a great tool for sound, just don't let it own you.
I say keep your fav pedals, and get you a multi effects proc. along side of it. I mix the two now, I used to have a ton of pedals, too many, it got to where I would be lugging more pedals with my music than my guitars and amps! Line-6 POD's or even Line-6 amps are awesome and have a ton of sounds programmed, plus with POD's you can create your own sounds and have endless sounds.
Just my nickel in the hat though
FrEaK
