E
EDAN
SonicAlbert said:An important point that gets overlooked in discussions like this is that these people do not use *only* Behringer gear. They've probably got killer signal chains and processing to use. The Behringer gear would be like cheapy little toys that get used in special situations. Big difference.
There are plenty of people that keep old Alesis gear around too, and other low cost gear as well. It might do one thing particularly well, or have a sound that is just right for specific purposes. But that is misleading to imply that therefore there is no difference between Behringer and high end gear.
When Tony Visconti says something like what is quoted above (if indeed that is what he said) I don't think he necessarily knows to what extremes his quote will be taken to. I don't take that as an overall endorsement of Behringer or cheap gear in general. He uses expensive gear and cheap gear, and is basically saying they all have their uses. But the way I take it, what he said cannot be taken as a blanket endorsement of cheap gear.
As someone who has toured, I can say that I don't like it when I go into a venue and see Behringer gear in the rack. It just says to me that the house is cheap. The best sounding live gig I played had top end gear, from the DI's and monitors to the board and to the outboard. It sounded incredible, the difference was plainly obvious.
This whole argument about Behringer and low cost gear is in part because people that get defensive about not having high end gear. It's like the "my dick is bigger than your dick" thing. They don't have the big swinging dick gear, so then they say that the cheapo stuff is the same thing, so they don't feel insecure. Silly.
I'm fully expecting some negative REP for that last paragraph.
I will say that I own a couple pieces of Behringer gear, and recently ordered yet another unit that Behringer makes. But the difference is I don't kid myself about it, I buy it because it is cheap, serves a function, and I use it in non-critical situations.
The part about being defensive is the silly part. Personally I can afford all the high end gear I want, I have some middle of the road gear and some cheap gear, have had some high end gear in the past and most all of it produced good/great results when used properly. The problem with your statement is some impressionable newbies are reading your words thinking they have to go out and buy a $1,200 pre and a $600 direct box and a $2,200 reverb when in reality you can spend a 1/3 of that and get results that are of very good quality.
Saying that the pros mentioned use behringer gear specifically for some type of cheap effect and not for the quality of performance for that which the specific gear is intended is nothing short of irresponsible, a uniformed opinion on your part that does not reflect in any way reality. You don't know these people, you haven't asked them. I know for a fact that Tony used Behringer compressors on Bowies albums for the vocals and some instruments and not for any kind of one-off cheapy effect kind of thing, pick up Behind The Glass and read it all for yourself. In researching the pros who use Behringer gear there was nothing to insinuate any of them used the gear for anything other then what it was intended for.
Boston and Kansas both recorded their first albums 30 years ago on a consumer deck, a 1/2 Tascam 80 8 track bouncing tracks to no end, those album sounds better than ANYTHING recorded out here, far better. Tom Scholz of Boston had access to a "real" studio but choose to do it at home with a recorder that cost a 1/10 what a 2" analog deck cost back then. Just another example of what could be done on cheap gear. Heck, Page used a 20 watt practice amp and ran it through a 6x9 speaker on much of Zeps first album. People went out and spent thousands on Marshall Amps trying to get that sound! Primus did their first album on a lowly Tascam 388 1/4 deck .. Still sounds better than ANYTHING out here. Neil Youngs Sugar Mountain was done on a cassette recorder. If you feel you need high end gear to get pro results so be it, but like Tony said, it's not the gear thats the problem.
