C
charger
Hell if I know, man. Just twist knobs until it sounds right!
No, seriously, I think i plug into the front input, then I set up the input gain to get the levels nice and hot. If you listen whil you;re doing this, you can hear when it hits the distortion threshold, you'll want to back off of that a little. Then I set up the compressor, usually with my standard bass compression settings, 5-10 ms attack, .5 sec (500 ms) release, ratio around 3:1 - 5:1, then i crank the amount knob, and adjust the input gain until it sounds right. From there, if you need to, you can add a little eq, bring up the low end, cut a little on the highs, this all depends on your taste though.
Then adjust output gain to get healthy levels hitting your recorder of choice, and you're done.
