BushmasterM4
Didnt take long at all. Maybe and hour. Next ones will be quicker. I will assembly line them. Im using 2" Roxul 60 panels (2' x 4'). For the lumber I used 1x3 premium furing strips (Lowes). I cut those at 4' for the sides and 25 1/2" for the top and bottom. I joined those by utilizing a corner clamp and 1 1/2" drywall screws. I pre-drilled and c'sank the holes for a flush finish. I then rounded all sharp edges. Next I stretched and stapled the burlap (JoAnn Fabrics). Then I placed the Roxul panels in. They were a nice tight fit. When I was at Lowes I bought some 24" insulation hangers. I thaught they would be over 24 " wide, and went ahead and got them. Well they are exactly 24". They are designed for 24" on center building applications and are put in between the joists (with a bow in them) to hold up insulation. So I was thinking at least 25". Nope !!! But I got them to work by drilling some holes for them to stick into the corners. The next one I will staple some old 1/8" molding I have onto the inside (at 3 places) to shrink the inside dimension so I can put the wires straight across. I will post a pic of the next one. I am making 16 of these (1/2 black and 1/2 white) to go with the red walls in the control room. The black ones I am going to paint the wood edge facing out black. You can see from the picture the wood showing through. Anyway, Im gonna head back out and get some more done. Here are some pics
), and frequencie response and image are better now... (room is small, 11 x 9,2 x 8,6)
