dturcotte
OK guys... be gentle...
I have 2 pods presently and am about to add a third. I have basically just recorded through the pod and have not used the outputs at all (except for monitoring).
Here's my question, and again, please be gentle
I use a Behringer MX9000 as a mixer prior to input on the pod. And I usually just "mix in the box". But what i would like to do is come back out of the pod and back into the "mix B" section of the Beri on channels 25-48. I would just like to play with the idea of mixing through the mixer and see if I like it or not.
So, the question is, if I have 3 pods, do i just connect the outputs of all three pods to the designated input of the mixer and then route my ouput as necessary? Also, do i just select the track(s) and send to say bus1, bus 2, bus 3, etc...?
Let's say I get that far, what would be the best thing to mixdown to? CD Recorder? Dat? Or should I just route the main output of the mixer right back into the pod?
Thanks in advance for your help...
