H
Hi_Flyer
finally got the MX5050-8.... brought it home to play with but I'm having trouble with my mixer. I have a Mackie Onyx1220, which the manual says is a +4, the Otari has an input level trim control, so the -10/+4 mismatch shouldn't be an issue, right?
I tried to simply patch a stereo recording to tracks 1/2 on the Otari through the mixer, I patched it from channels 1/2 on the Mackie with gobs of gain (clipping the hell out of the channels on the Mackie) but its barely moving the needle on the Otari. I also tried taking the signal from the ALT3/4 outputs and same deal, barely a whisper of a signal...
Then I plugged an Audix i5 -> Rane MS 1B -> right into the input on the Otari and it seemed like it was working OK. It was a helluva lot hotter at least, I dunno if it was where it needed to be, but it was better and got the needle into the red.
So any ideas whats going on here? I gotta be mis-matching something, right? The Mackie has a Dsub connector for the recording outs (which I used with my Tascam 38) but I don't have the break out snake with the XLRs. I suspect I need to be taking the signal from the Dsub connector in order to do this correctly, but there has to be another way to do it.
A signal from the main output should be moving the needle, right? could it be the wrong kind of cable? I was a using a balanced XLR -> 1/4" connector, but I don't know if there is some kind of impedance mismatch.
Any ideas? Should I just get a new board? I have thinking about it, the 1220 is a little underpowered for 8 track recording/monitoring.
I'll call the dude that sold it to me tomorrow and make sure he tested it. I suspect its something I may be doing wrong though....
could this have something to do with the way the inputs are wired, i.e. unbalanced XLR with pin 3 hot? do I have to get special cables that are wired differently?
