Massive Master
www.massivemastering.com
That "foam" isn't doing you any favors.  It's literally absorbing what your recordings are lacking ("air") and leaving the boxiness (which all makes sense now because of the proximity to the wall).  I revert to my previous statement -- Lose the drywall, fill with the heaviest weight (or rigid) fiberglass* or rockwool you can, staple thin nylon screen taught to the studs, staple some sort of tight weave cloth over that, and get some nice cedar 1x0.25 furring** strips to make it pretty.  In a walk-in, you have at least some space to absorbent mass.  In that space, you literally don't have enough space for the amount of mass you need.  Doing that floor-to-ceiling would be best, but if that's an issue, leave the top and bottom foot as drywall (but try to stuff the studs).
* I've used rigid fiberglass ceiling tiles in some cases for smaller spaces - It's typically foil on one side, but that's not a big deal in this case (as long as you don't have the foil side out on the final layer). It's nice because it holds its shape and it doesn't shed much. The downside is that per cubic foot, it's more expensive. The upside though - It's more mass per area as it's somewhat compressed. Blah, blah, blah, rigid fiber will do you better than squishy stuff. But you're not worrying about a lot of bottom end here, so at least "heavy" stuff (again, Roxul Safe and Sound or something in that vein) will certainly be a gigantic improvement in what you've got going on now.
**Fur-ring in this case. But "for" is still "four" not "fir" -- Sorry. To me, that's still the really important part.
[EDIT] Dammit. I just read back a bit and saw the word "apartment" in there. Okay, scratch all that. (Dammit)
3" Auralex (NOT CHEAP CRAPPY FOAM which is worthless - Auralex is already cheap for what it is - the junk from the local "Foam Center" is - well, it's junk). You can get 64 sq. feet of 3" Studiofoam for a little over $400. You can attach it to drywall using T-pins (fast, effective, easy patch if you decide to leave the place). If anything is going to turn a closet into at least something reasonable and be temporary *and* cost-effective, this is where I'd put my $$$.
Actually, I'd probably still cut the drywall but I'd be really careful about it so I could reuse the pieces that get cut out when I patch it and the end of the lease.
[EDIT AGAIN] Another option, possibly less expensive but definitely more work, would be to make (or have someone make) cloth "bags" for rigid fiber tiles. Again, more mass than the foam. I'm not sure how large that space is - But lets say it's 4' x something. You could get some pretty heavy duty "screen" (tight chicken wire) and make a piece that's - whatever, 4'x6' for a side wall -- Poke through the panels (3 or 4 thick - something over 2") with an awl or something, follow it up with a cable tie, strap it to the screen. Leave a few inches at the top to hang it from the wall. Wrap the whole thing is relatively dense cloth (some nice cotton duck - something to keep the fibers inside). Make one for each wall and get a single sheet of Auralex or something for the ceiling.
 what’s a gobo? Can you post a link?
