musicdavid
Member
I have never encountered an interface with inserts.
The best way to do it is set up a hardware insert in your DAW. OP, what DAW are you using and what interface are you using?
Cheers
My recording set up is (generally):
Instruments/vocals >>> Mackie mixer >>> 4-track tape recorder >>> PC
The reason for the 4-track in the chain is so that I can record two tracks simultaneously, pan them hard L and R and record them to two separate tracks within Cubase.
I agree with a previous poster about making sure that what you are recording is nicely balanced to avoid having to fix it later, but I would still like advice on possibly using an external piece of compression/reverb hardware within my set-up during mixing.
