Expensive Mics vs. The Mixing Process...
  • Thread starter Thread starter Robertt8
Robertt8
Robertt8
Why do you need $10k mics when most mixers EQ the living crap out of every track to get everything to fit together?
The more i see about people that mix, the more i see (depending on the track) there is very little left to that track by the time it gets to the final mix...assuming you've got lead vox, background vox, a couple guitars, bass and drums.
Am I insane?
Because when you start EQ'ing, it's like Phandora's box, and you never really know what you're going to uncover.
What you're doing (when you EQ) is just highlighting/emphasizing certain things while de-emphasizing others. For example: If you're going to boost the high end on something, then hopefully you've got good, smooth high end to start with ... because if you don't, that will certainly be revealed once you start boosting it. Like shining a spotlight on a big zit or something. :D
Robertt8 said:
Am I insane?
Yes, you are insane. But that's beside the point.
Am I insane?
Because you don't understand mixing vs. tracking.
Tracking is getting the sound of each individual instrument right.
Mixing is making all the instruments fit together in a cohesive performance that is balanced and pleasing. These are two totally independant fields in the professional market. The producer is the one who makes the performance out of the song. In tracking, you record the raw performance and keep it for later production. When mixing, tracks may be cut, edited or added all in the name of contributing to the overall song. Not what the guitarist or singer wants the song to be. The producer is the *band* effort and the one who is removed from being in a subjective situation.
Gigo
Garbage in, Garbage out: A mix is only as good as it's source tracks. While it may be easy to make a good recording sound bad, it is impossible to make a bad recording sound good.
Also, any engineer who has been around the block more times than we peons have will tell you it is far more desireable to use microphones and placements in such a way where the tracks will require little to no EQ in the mix stage than it is to "fix it in the mix." EQ (or any other processing, FTM) should be used sparingly and only when necessary. If you have to EQ a track more than a couple of dBs here or there, there is a problem with the recording.
G.
ACOREC: I agree to a point. obviously the two are completely different aspects to recording, but the fact remains that those tracks WILL sound like shit solo'd once you make them work in the complete song.
SOUTHSIDE GLEN: I agree that garbage in, garbage out, but related to the note above, the track solo'd once slapped in the song will shit on it's own...nothing like the original "mic'd" version.
It's too bad they don't have mic's that record with the song in mind. I know that would be impossible as there are countless variations, but if you could your nice thick guitar so it sounds like shit it would be fine as long as you knew it would fit in the mix
Ah, but that's exactly the point I was referring to when I said to use mic usage and placement to make a track that requires as little EQ as possible. Let me amplify that somewhat by adding a phrase to the end of it; use mic usage and placement to make a track that requires as little EQ as possible to make it sonud right in the mix.
I read somewhere an interview with a famous engineer/artist pair (I'm sorry, I forgot just who this was, maybe Mark Knopfler was the artist?) His method is to go into the studio with an agreed idea from the start of what the final mix will sound like, what the sonic spaces should be for each instrument and element. They then spend the majority of their studio time budget selecting the right mics and placements, they then get the tracking just right and never touch an EQ; not only getting a great sound but saving on studio budget in the long run by cutting down on time in both the mixing and mastering stages.
Not everybody can or does work this way, and it may be a bit of an extreme example, but I think it illustrates the point perfectly; there is no way they could have success with this method with nothing but a couple of SM57s.
Quality mics at least give the opportunity to make proper tracks that will work in the mix. Poor or incorrect mics won't even give you the opportunity; your mix is going to suffer no matter what.
G.
I have yet to meet a professional mixing engineer who only mixes and who doesn't eq like crazy, even when the best of gear and technique was used to track. Very few songs that hit radio aren't mixed by someone completely outside of the recording process...in most cases I can name you one of the 5 guys who probably did it. And it is all processed like crazy. Robert is correct in thinking like that.
Another thing, though, is that when you're talking at the top level in music production, you're talking about REALLY nice EQ's. They actually enhance the sound rather than taking from it. Sometimes they use EQ when it wasn't even necessary just because that EQ sounds good or right for the song. The gear is part of the sound. That's why everyone wants their stuff mixed on SSL's. Cause they sound great, and you can tell if it was mixed on one or not. If some of that gear wasn't musical and good sounding, then everyone would be mixing top40 on a behringer.
H2H
I'm not saying that's not true, but I'll also say that I have yet to hear a professional engineer who doesn't believe (and practice the belief) that if you have to EQ any given track by more than 2 or 3 dB here or there, you have a real problem with the original track. Now, maybe there are real problems with the original track and they *have to* use excessive EQ to "fix in the mix", but if that's the case that's either because the tracking engineer didn't do their job well or the artist thought they didn't have the time or the budget to spend on the tracking, not because the mixing engineer "wants" to use excessive EQ.
You are absolutely correct that an SSL or Neve EQ section has "that sound" and can wipe the floor with a prosumer Mackie or Yamaha EQ. No disagreements there. But that does not mean that a decent EQ section is a blank check to "EQ like crazy." No matter how good the EQ section, use of EQ adds extra length to the signal chain and - by the very nature of how all EQs work - adds some degree of distortion and phase problems to the signal.
All else being equal (no pun intended), a good engineer would rather not EQ if they didn't have to. And - to return this to the point of the thread - a quality microphone selection (combined with the proper knowledge of how to use them) reduces and often eliminates this need.
But let me flip the whole conversation around for a minute. Listen to a quality recording of a Yo Yo Ma cello solo or of a Norah Jones vocal. They sound just gorgeous, don't they? Why is that? It's becaue the enginer picked the right microphone, and more ofthen than not it's not a $199 mic. It's not because they used an NT1a and EQ'd the hell out of it; if they tried doing that it would sound inferior, no matter who the engineer and no matter what board he used.
You mean they're ... not? (gulp!)
The thing about this whole conversation is that, really, everyone is right.:)
There are just so many production styles and genres that each technique really has its place in the world of music. I'm a big, layered sound, pop/rock/top40 sound type of producer and writer. Frankly, it's alot easier for me to do a really thick mix and make it sound great. I tried recording a jazz singer with just her and piano one time as a favor. They really liked the result, but I thought I sucked at it cause I know that's not my thing. With only 3 tracks to work with (1 vocal, 2 mics on the piano) my lack of personal gear shined clearly.
H2H
Okay...I don't believe this really either. I mean when EQing say the snare (this is just a general sample), you tend to roll everything off under 150Hz, Bass guitar you can roll everything off at 520Hz and boost generously at 2kHz if those aren't boosts or cuts more than 2 or 3 dB, than i don't know what is. Every instrument has huge chunks of it's sonic spectrum that can either be seriously rolled off or cut to make the sound better in the mix...and often has to be to make it sound better.
A U87 takes EQ a whole lot better than a Behringer B1. That's part of it. You can screw with the sound a lot more when using a quality signal chain. Frequency response is not the only issue with microphones...It's smoothness, clarity, fullness, and whatever other words you want to use to describe it.
OK, you are absolutely correct there (though boosting the bass in the mid-highs is commonplace, one typically should not need to do it more than a few dBs, but that's a hair-splitting point here).
Rolling off unnecessary or unwanted portions of the spectrum is not what I was referring to, though. That has nothing to do with the quality of the microphone or microphone technique; you are going to get stuff under 150Hz on a snare that you may want to roll off whether you're using an $80 SM57 or or a $3500 Royer ribbon mic. It's the EQing of the stuff "you want to keep"
that's the main point. The better your microphone usage, the less you should need to EQ.
And also, if done well, the less you have to get rid of with shelving or radical parametric notching. You are absolutely correct that you need to get the instruments to fit in the mix spectrum-wise, and that EQ is an effective tool for doing so. However, it will sound one hell of a lot better if your microphone technique takes this into account. Using complimentary pairings of microphones that by way of their natural tendencies/sounds work and fit better together and keepng the EQ to a minimum will, nine times out of ten, sound a whole lot better than slapping a couple of standard microphones out there and throwing massive amounts of boost/cut equalization at them to *force* them to fit together in the mix.
This forum is constantly barraged with questions like "which is better for miking a guitar cab, the SM57 or the U87?" Good lord, there are so many other variables involved that it's impossible to give a single definitive answer to that question. Not even counting a dozen other factors like music style, cabinet type, guitar model, etc., there are also the very important factors of desired sound and interfacing with other instruments/tracks.
As far as "desired sound", that's directly analogous to H2H's example of the SSL EQs. Just as no matter how much you try and tweak you'll never get a Mackie EQ to sound like an SSL EQ, it is equally true to say that no matter how you tweak or EQ an SM57, it will *never* sound like a U87. Period. (and the same goes in reverse, too, FTM. There are times when a '57 will give you "that sound" that you just cant get from an '87 no matter how you EQ.)
And finally, as far as "interfacing", some mic combos just work better and "fit" better together in a mix. I might want to use an MD421 on a Telecaster when I know it will be competing for sonic space with a background vocal running though an AKG tube, but if I am using an MD 421 on a sax part, I might want to switch the Tele over to a '57 so there is less sonic competition. No EQ in the world could acheive the same results that such mic switching could. The differences in response are just too complex to model with graphic or parametric EQ.
And, while complex, the differences are never more than a few dB at any given frequency. It's not like a U87 is ever going to be 6 or 8dB hotter or quieter than an SM57 at any point in the spectrum (except maybe at the extreme fringes.) The differences are usually miniscule at any given frequency, certanly rarely more an a few dB. Yet they capture one hell of a different sound, don't they? There is no mistaking the differece between a '57 and an '87. Even a deaf person could *feel* the difference. The exact same principle is true with EQ; one should rarely, if ever need to use more than a few dB boost/cut at any given frequency to radically effect the sound.
G.
Okay...I don't believe this really either...
In the end, all sound and music is just opinion.
If it sounds good to you, then it is good.
But some people like the sound of accurate sound capture and recording. Figure that musicians spend their entire career trying to perfect the sound of their individual instruments, and the sound of their bands. So one philosophy is to try to "capture" this already-painstakingly-perfected sound, and make only small adjustments to that sound to compensate for imperfections in the recording process.....or maybe enhance it slightly. People who enjoy hearing sound as it came from the original artist appreciate this.
But it is still just an opinion.
If you like the sound of +12 bass boost and all the midband cut -12 dB....that is good also. :)
Personally, I always try to capture the best sound I can out of a source. This means using the room, selecting the mic, and selecting the proper preamp and or compressor. In general, better mics just plain old sound better. If during the mix it takes more EQ than I thought to make it sound right, then oh well. At least you can make it sound right. The problem with the whole solo'ing of a channel in a mix is kind of a moot point to me. So what if it doesn't sound as good as you might think when it's solo'ed? As long as it sounds good with the rest of the tracks. Sure you could try and pick something that makes it sound like that from the get go. Often times though that would mean recording a track with such an odd setup that you have no options during mixdown. The problem here is that during the tracking phase, the feel of the whole song most likely has not made itself known. Not only that, but very few bands that have a real recording budget and a huge arsenal of tools and knowledge go in to the studio knowing exactly what they are going to do on every song. Once in the studio often times parts are rearranged, rewritten, layered with stuff that they did not previously know they were going to do, etc... Its a process. The best way to deal with a process is to get the best sound you possibly can. PLus, when you have a different mix engineer than tracking engineer, the whole feel of the song can get changed yet again. If you were to record all the tracks with what you THINK is going to be the way those tracks should sound when solo'ed in a mix, you are really severely limiting your options come mixdown. If you just record the best track that you think you can, then when you get to mixing you should have some options. Personally, if you have decent EQ's, I would not be afraid at all to use them. Even if you have to go + or - 10 with them. Sometimes the image you have in your head of how a given track should sound when you are tracking it ends up very different than the one you hjave by mixdown. Using better mics and preamps etc... leaves your sonic palette much more open to a future change. I would not consider it a tracking mistake, just a change of mind or approach.
You don't, you just need Anteres Mic Modeller. ;)
I think that in the project for hire studio domain, the low budget customer hasn't the patience, nor the perception of value in seeing large chunks of time spent on switching out and moveing around mics. That's a luxury of the well budgeted, label backed project. For the artist or band recording themselves, it SHOULD be the luxury they bought into by getting off the studio clock and into their own private studio.
For the pros, I'd point to one of Steely Dan's liner notes, which read something like ( the last half I believe is verbatem)..
"Considerable time was spent selecting and placing microphones, with individual track equalization heavily frowned upon".
That's how it's supposed to work, but then they set some records for time and money spent on their albums.
-RD
awsome thread people, thankx
although it is making me think about how bad my entire chain SUCKS
Having a lot of nice mics to choose from can minimize the use of EQ during mixdown.
War
