			Tremaine
Chancellor of the EOPA
I copied this from my M-audio Delta 1010lt <pci sound card> manual.
""{at the delta analog outputs, a +4dBu setting will give you the most headroom for recording. allowing the Delta 1010lt to accept a hotter signal level.""
...this means the device sends a hotter signal, therefore the +4dBu setting is cut or has less gain compared to a 'consumer' <-4dB> or -10dBV signal?
