Ex-cert from Delta 1010lt manual
  • Thread starter Thread starter Tremaine
Tremaine
Tremaine
Chancellor of the EOPA
I copied this from my M-audio Delta 1010lt <pci sound card> manual.
""{at the delta analog outputs, a +4dBu setting will give you the most headroom for recording. allowing the Delta 1010lt to accept a hotter signal level.""
...this means the device sends a hotter signal, therefore the +4dBu setting is cut or has less gain compared to a 'consumer' <-4dB> or -10dBV signal?
Or to be more precise you want to use the appropriate levels (voltages) depending on what the next piece of equipment is expecting
sending a +4 dBu signal to equipment expecting -10 dBv levels could cause distortion, clipping maybe even damage as you are sending way too much voltage in
The other way around wouldn't be as bad although sending -10 dBv levels to a device looking for +4dBU would be a very low signal
You want to calibrate your soundcard/converters based on what level of signal your analog gear will be sending/receiving
